Hello, I just came across an omission at the SITL for Windows documentation.
The final command of section Install Required Python Packages:
python -m pip install --user lxml
fails with error:
In file included from /usr/include/libxml2/libxml/parser.h:810:0,
from /usr/include/libxml2/libxml/xmlerror.h:10,
from /usr/include/libxml2/libxml/xpath.h:26,
from /tmp/xmlXPathInitKp6gpK.c:1:
/usr/include/libxml2/libxml/encoding.h:28:19: fatal error: iconv.h: No such file or directory
compilation terminated.
Could not find function xmlCheckVersion in library libxml2. Is libxml2 installed?
error: command ‘gcc’ failed with exit status 1
Command “/usr/bin/python -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-Zp4od7/lxml/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-aR1FvW-record/install-record.txt --single-version-externally-managed --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-Zp4od7/lxml/
I have followed the instructions found here, installed “libxslt-devel” from the cygwin setup and the error went away.
Please update the documentation to include “libxslt-devel” in the list of packages for the cygwin installer.
