Hi there,
Has the support for Displays been removed from firmware since 4.5?!
#NTF_DISPLAY_TYPE
https://ardupilot.org/copter/docs/common-ntf-devices.html#oled-displays
Hi there,
#NTF_DISPLAY_TYPE
It is possible that this feature is deactivated by default, depending on what board you use.
You can see here, which features are deactivated for each board: List of Firmware Limitations by Board
If it is indeed deactivated for your board, you can create a custom firmware where the feature is activated here: ArduPilot Custom Firmware Builder
Interesting! … Thank you so much.
