Obstacle avoidance with UAV - R21F
how can i use UAV-R21F CAN obstacle avoidance module with orange cube. If i want more CAN sensors with orange do i have to use CAN splitter ?
this the link of the sensor
First of all, you have to check if this sensor is already supported by Arducopter, by checking the ArduCopter user guide ArduPilot Copter — Copter documentation. I never heard about of this sensor, I fear that it is not supported yet… but conduct a research by yourself.
If it is not available it, you can develop the sensor driver and contribute to the community.
I do not have much knowledge on this, and most probably the answer is “depends”, but maybe @ppoirier can clarify it for you.
Yes a driver has to be written, it should be relatively easy to reuse an existing CAN proximity driver.
Looking at the manual, it seems it is just outputting distance within a 28 deg FoV with no Bearings… making it less interesting for avoidance
@rishabsingh3003 is working on a multibackend proximity driver that should be released soon, making it possible to connect multiple proximity sensor on the same bus, providing the sensor can have adressing capability
This sensor is working under Benewake CAN sensor type.
What need configure in ardupilot to using this sensor? CAN driver to DroneCAN or Benawake? rngfnd1_type to 34?
Hi.
What driver im can using for this sensor?
Assuming @kalai1219 is right, and that you want to use CAN1, then set:
  • CAN_P1_DRIVER = 1
  • CAN_P1_BITRATE = 250000
  • CAN_D1_PROTOCOL = 11
  • RNGFND1_TYPE = 34
Bit rate may be higher depending on revision
Yes working… thanks… my sensor have broken cable((
good to hear that you got working. What parameters changes you finally achieved .
can protocol and range finder type to 34. But my sensor say always 16393 - im need debug what this maybe broken sensor…
I am having same R21 radar for obstacle avoidance, I have tried the same method provided into the thread but I’m not getting any output from the sensor. I have connected the external supply of 12 volt and can h and can l are connected in the middle of can 1 port
Hello, I’m getting the same error. Were you able to solve it?
Hello Evgen_Stenkin,
        I am also facing the same issue of 163.39, seems the same issue. Did you get chance to crack the issue.
Hello Kalai,
I am trying integrate the UAV-R21-F obstacle avoidance CAN module with Ardupilot (4.4.3) by enabling the following macros and parameters. However, I am not getting the values from the sensor. Am i missing anything? kindly help
Macros in hwdef.dat
define AP_RANGEFINDER_BACKEND_DEFAULT_ENABLED 1
define AP_RANGEFINDER_ENABLED 1
define HAL_NUM_CAN_IFACES 2
paramters
CAN_P1_DRIVER = 1
CAN_P1_BITRATE = 1000000
RNGFND1_TYPE = 34
RNGFND1_MIN_CM = 100
RNGFND1_MAX_CM = 2000
RNGFND1_ORIENT = 0
PRX1_TYPE = 4
Hi @Vinoth_Kumar1 try PRX 1_TYPE = 14 (or)
Try UAV- R22-1 with Serial port
Have you used Bec for 12V , if yes then which one you used
For example - iFlight BLITZ BZC
will you please share the parameter list
