You can start reading the wiki : http://ardupilot.org/dev/docs/code-overview-object-avoidance.html
The native driver is now implemented in ArduPilot
http://ardupilot.org/copter/docs/common-benewake-tfmini-lidar.html
I have the message : PreArm: check proximity sensor
I use a TF mini connected in serial 4/5 on pixhawk (last firmware ARDUPILOT). It give the good value in MP.
I have configure an avoidance switch but i have always the message. Any ideas ?
My parameters
AVOID_MARGIN=2 : nombre de mètres devant l’obstacle (avec GPS)
[AVOID_DIST_MAX] =5 : nombre de mètres devant l’obstacle (sans GPS)
[AVOID_ANGLE_MAX] =1000 controls how far back the vehicle will lean away from the barrier (sans GPS)
SERIAL2_PROTOCOL = 9 (Lidar)
SERIAL2_BAUD = 115
RNGFND_TYPE = 8 (LightWareSerial)
RNGFND_SCALING = 1 coefficient d’echelle
RNGFND_MIN_CM = 30 : distance mini de lecture du capteur
RNGFND_MAX_CM = 600 : distance maxi de lecture du capteur
RNGFND_GNDCLEAR = 23 : (en cm, distance entre la tête du capteur et le sol)
RNGFND_ORIENF=25 : (orientation vers le bas)
PRX_TYPE=4 : type de capteur de proximité
PRX_YAW_CORE=0 : correction sur le yaw
In mission planner the sensor is on flight mode 1
CH7_OPT = 10 : switch channel 7 for proximity sensor
Bonjour,
Have you tried changing orientation as 25 (RNGFND_ORIENF=25 : (orientation vers le bas)) is used for altitude.
And then, you hit CTRL-F to get into the proximity ‘‘radar’’ screen.
Bonjour,
My application is to clean the roofs by drone so I need to maintain a constant altitude so a rise of 2 meters between the drone and the roof. Orientation as 25 is ok for my application but I have the message : PreArm: check proximity sensor. My TFmini is installed 23 cm up to the ground. Any suggestion ?
I think the error is : PRX_TYPE=4 : It need to stay to 0 ; i’ll try to fly this afternoon
Type 4 is for rangefinder
Line 47
Hey there!
I was looking for a low cost and effective rangefinder for obstacle avoidance for a drone. 4 at sides and one for altitude. Cost here is priority but effectiveness is also important.
Can anyone suggest rangefinder for this purpose.
I found tf luna interesting but found threads where it is giving issues with the performance of the drone.
Thanks
Shubham Thakur
Hey all.
curious if you want to use two TF-Mini’s do you need to set the addresses to different values and if so how. This is for I2C lidars.
cheers
Hi… Actually I had also done the same…but if we switch on proximity avoidance…if that obstacle is nearer to that…the drone is shaking and dropping down (landing)…So can you please tell what can I do to move back…
check this parameter
AVOID_BACKUP_DZ: Avoidance deadzone between stopping and backing away from obstacle
Distance beyond AVOID_MARGIN parameter, after which vehicle will backaway from obstacles. Increase this parameter if you see vehicle going
