I can’t find a data sheet for this motor anywhere.
I’m having a little trouble with this motor and AM32 firmware. The AM32 firmware configuration needs to know the number of poles - and is set to 14 - perhaps a default.
I know a lot of people have used this motor - and I have a faint recollection of this question coming up for me a long time ago.
If anyone knows of some specifics, I’d appreciate the help. Thanks!
I was going to suggest verifying the pole count on your topic regarding misbehavior of this copter. Seems a logical place to start. I do not have any more info about that motor combo, though.
Thank you @Yuri_Rage and @Allister - Yes it the motor does seem to have 14 poles.
I’ve been chasing down a problem with my first AM32 ESC that caused the motors to violently vibrate on the workbench without props doing a motor runup in stabilize.
I found out this afternoon that the problem was with option called Complementary PWM.
As I read the info I could find, this option should improve motor efficiency - but it requires ESC hardware to work. So I guess mine doesn’t have it.
I think I may stick with BLHeli_32 until AM32 is developed a bit further - with documentation to match.
