I’ve opted to stand up my own base, because the fix comes faster when I use multiple constellations and L1 & L2, where the unavco resources near me are all GPS-only.
It takes a little longer to get a fix, and harder to keep it - plus at least at one of my sites, the baseline is a bit too long at 100km.
I’m trying to figure out how this works in Iowa. I have a Spider Business Center (SBC) account, but can’t see how to connect an NTRIP service to Mission Planner. I don’t see any correlation between SBC services and the url required by Mission Planner.
I did find the server address and port after a google search: 172.206.203.10:10000. And I know I am using the correct username and password. Still, the common error appears. I think I have to request an access time slot. Even though I have a subscription, I have to request a 2-hour time slot it looks like.
I believe I would enter: http://[username]:[password]@165.206.203.11:10000/0107
At least Mission Planner is returning with the error, “No connection could be made because the target machine actively refused it 165.206.203.11:10000”
I am attempting to use the NTRIP service along with a mobile base GNSS unit. I am able to establish communication to both from my laptop, but nothing is going on without a connection to the autopilot. Does there always have to be a connection to the autopilot? I would like to perform a ground survey for placing Ground Control Points. Preferably, I’d like to use an RTK setup using the NTRIP service plus mobile base. Is this possible with Mission Planner?
Is there a method for performing a normal ground survey through Mission Planner?
I am using a CUAV 9Ps GNSS unit as my rover (moving base). This unit has to be connected to a PC or an autopilot in order to use it. My thought is that I could use the CUAV 9Ps the same way you could use an Emlid Reach RS2+. Just connect it to an NTRIP service over a mobile connection, and go collect data points on the ground.
Data needs to be encapsulated in a MAVLink telemetry stream to be used in Mission Planner. I made a survey tool like you’re talking about using a cheap autopilot, a Zed-F9P module + good antenna, and 915MHz telemetry.
What purpose though does the Moving base option provide in mission planner? Under the CTRL+F menu, there is this option for including a moving base, (connected to the PC), in addition to the stationary base or NTRIP service.
Is there also a way to store the RINEX data on the autopilot for PPK processing? My base unit is the CUAV C-RTK 9Ps, which does not support internal PPK logging.
I just got a SpeedyBee to work as a ground base host unit.
Not to my knowledge. Using an autopilot as a fixed base station is an odd case. If you want to post process, recommend a more robust fixed base station.
