Hello I recently updated the firmware to 4.1.1 and many parameters like NTF_DISPLAY_TYPE are missing. or disabled by default.
Can you assist to enable them.
best regards
best regards
have you looked in all parameters and not just parameter tree?
yes I have checked thoroughly
You are probably on a 1Mb board. This was removed from some boards due to flash limitations.
may I add this parameter to support an onboard display or I have to upgrade to another board
Try the custom build server to get a build for your board with the features you want: https://custom.ardupilot.org/
thank you. I tried a custom image and I can set the parameter. Still I have problem with the display probably because of a conflict on the I2C bus and the buzzer with the custom image doesnโt work i.e no arm sound .
