You went the wrong way with the Pitch/Roll Rate D-term. Try dropping them to .002
You need toi configure the Notch Filter before attempting Auto Tune. So set these and make a simple AltHold hover flight to collect data to do so:
INS_ACCEL_FILTER,10
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,4
PSC_ACCZ_I,0.4
PSC_ACCZ_P,0.2
Use the Initial Tune Parameter screen in Mission Planner and update all those parameters, you have some at default still.
Then lower the Rate Pitch/Roll P&I values to .08 and the D-terms to .002.
And set these notch filter parameters:
Thank you so much, could you please let me know which GUI is this for notch filter and how do I access from MP?
Initial tune is at Setup → Mandatory Hardware → Initial Tune Parameters correct ?
Hope I can still keep INS_GYRO_FILTER to 20 or raise to 42 as suggested by the calculator for a 10 inch prop and 3s battery
