Hello, I recently received my matek f405 wing board and tried to upload arduplane on it, I used both betaflight configurator and the I-Nav configurator and both have the same issue.
When trying to upload the local firmware, it goes into rebooting to ROM bootloader and then the board makes the disconnect sound and then it propts failed to open the serial port.
How can I fix this, and what other ways can I try to flash the firmware
do you have any peripherals connected to the FC?
press boot button while plugging the board into your computer to get it into DFU mode and try to flash again with the bl.hex file.
yeah when DFU is pressed in the PC it.s as STM32 BOOTLOADER but can’t select it in betaflight or i-nav, it doesn.t even show only the manual selection option is available and nothing is shown
download Zadig https://zadig.akeo.ie/
when you have STM32 BOOTLOADER visible in Device Manager, open Zadig, click Options, List all devices, select STM32 BOOTLOADER, click to upgrade driver, after that with the FC still in DFU mode use INAV configurator to flash the bl.hex on the FC.
