Hi All. I’m trying the following set up: Multirotor with Pixhawk FC connected via 433 MHz radio link to Windows PC running Mission Planner (this is the ‘master’, used for arming checks, mission planning etc), which in turn is connected via Ethernet cable to Mac notebook running QGC (this a ‘slave’ used for visualization purposes during missions).
I followed mainly these instructions: http://ardupilot.org/dev/docs/mavproxy-on-windows-7.html , and I think I got close to having the setup working, however neither MP on the Windows PC nor QGC on the Mac are able to actually connect to the Pixhawk and get parameters/data - MP is stuck at ‘Getting Params’, and QGC does not connect; however neither of them gives an evident error message
Following is what Windows command prompt shows:
C:\Program Files (x86)\MAVProxy>mavproxy.exe -master=“com3” -baudrate 57600 -out
192.168.0.10:14550
Auto-detected serial ports are:
COM3 : USB Serial Port (COM3) : USB VID:PID=0403:6015 SER=DN00BE75A
Connecting to COM3 : USB Serial Port (COM3) : USB VID:PID=0403:6015 SER=DN00BE75
A
Connect COM3 source_system=255
Running script (C:\Users\Joe\AppData\Local\MAVProxy\mavinit.scr)
Running script C:\Users\Joe\AppData\Local\MAVProxy\mavinit.scr
-> set moddebug 2
-> module load help
Loaded module help
Unknown command 'graph timespan 30’
Log Directory:
Telemetry log: mav.tlog
MAV>
LOITER>
LOITER>
LOITER>
LOITER>
LOITER>
LOITER>
LOITER>
LOITER> APM: PreArm: GPS numsats 5 (needs 6)
APM: PreArm: GPS speed error 1.2 (needs 1.0)
APM: PreArm: GPS speed error 1.0 (needs 1.0)
192.168.0.10:14550 -out 192.168.0.11:14550
A
-> set moddebug 2
-> module load help
Loaded module help
Log Directory:
MAV> fence breach
GPS lock at 1 meters
online system 1
LOITER> Mode LOITER
APM: APM:Copter V3.5.0 (633501f9)
APM: PX4: 33825946 NuttX: 1a99ba58
APM: Frame: OCTA
APM: PX4v3 002D0022 30345106 36353832
APM: PreArm: GPS speed error 1.4 (needs 1.0)
Received 774 parameters
Saved 774 parameters to mav.parm
APM: PreArm: GPS speed error 1.3 (needs 1.0)
APM: PreArm: GPS speed error 1.1 (needs 1.0)
APM: PreArm: GPS speed error 2.0 (needs 1.0)
I’m no expert, and this the first time I use MAVProxy: hope some of you guys can shed some light on this.
Thanks in advance for the support (and patience
Regards
Giovanni
