I’ve recently been building my first Quadplane with Arduplane (a T-1 Ranger VTOL) and the current readings from the current sensor onboard the Matek H743-WLITE I have installed in it outputs readings that almost exponentially deviate from the actual current.
When the three engines are idling or at a low throttle position, the readings are very accurate as confirmed by my multimeter, but when I increase throttle, the current readings will rapidly deviate from the actual current and I will get measurements of about 60-80 amps between the 3x small 1806 motors when just hovering.
My multimeter has a 10 amp fuse so I haven’t been able to precisely measure the actual current at higher throttle levels, but based off of how many mAhs are put back into my batteries after a flight I estimate they are twice as much as the actual readings.
How could I go about solving this? I suspect that a regular adjustment of the BATT_AMP_PERVLT parameter will not serve due to the nonlinear nature of this issue. Feel free to correct me if I am wrong since I haven’t touched Ardupilot in a couple of years.
Thanks for any help that you might be able to provide!
