Non gps lock or compass
Hello. I’m working with cube orange plus and here3 gps. What i have figured out so far is if load arduplane on my flight controller, gps works and i’m able to calibrate compasses no problem. Is anyone else having this problem?
I forgot to mention that i’m using the latest version of arducopter for helis.
Set BRD_BOOT_DELAY,3000 and see if that helps
The boot delay had no effect.
Set LOG_DISARMED,1 to gather a .bin log file and upload it to a file-sharing service and provide the link to it.
Also provide a screenshot of the HW ID screen in MissionPlanner.
Set LOG_DISARMED,0 when done.
Im still working on the bin log
There is a bin file i was able to create but its too large to send. I tried using google drive to file share but it’s not taking it.
https://filebin.net/2prnbgt44wd2ct9l/2023-03-13_20-22-30.bin
There is certainly GPS data in that log.
You appear to be under cover or too close to buildings (reflections, multipathing)
I can see these road blocks:
  • PreArm: Set H_COL_ANG_MIN to measured min blade pi
  • PreArm: Heli motors checks failed
  • PreArm: Collective below failsafe
  • PreArm: 3D Accel calibration needed
  • PreArm: Compass not calibrated
so there is still work to be done.
For the compass calibration, go outside and wait for a good GPS 3D Fix then do the calibration.
Thank you. yes i reloaded firmware so many times I stopped doing a complete setup till I figured out compass and GPS. I did try doing it outside but i wasn’t able to get compass calibrated or get GPS locks like i did with arduplane.
