A few weeks ago I was messing indoors with sonar sensors and lowered CRUISE_THROTTLE param to 0, and maybe some other params that I dont remember, so that the wheels wouldnt spin when switching to Steering or Auto. I could then hold my hand before one of the sonars and see that the wheels would turn in the right direction.
The other day I was supposed to go out and try some auto missions. Though when switching to steering mode I would not get any throttle out signal. Tried raising the CRUISE_THROTTLE and CRUISE_SPEED but still no signal out.
I have since reloaded the default params, changed firmware to arduplane and then back to ardurover and still no throttle out signal. Or at least not enough to move the vehicle but I can see a little raise in the tuning graph. See attached file, between 987 and 988 I turn on steering mode.
Though if I turn on auto mode I get around 20% throttle. See attached file, between 80 and 81 I turn on auto mode.
What am I missing here? Shouldn’t steering mode give the same throttle signal as in auto mode?
Pretty new to ardurover but I’m fairly certain that I have run the rover in steering mode and that I didnt have to give any throttle just steer away from obstacles with the remote control.
My params:
STEER2SRV_P = 2
TURN_MAX_G = 1
NAVL1_PERIOD = 6
SPEED_TURN_GAIN = 100
CRUISE_SPEED = 2
CRUISE_THROTTLE = 20
Full parameters list attached.
Sonar sensors have been removed and
RNGFND_PIN = -1
RNGFND_TYPE = 0
RNGFND2_PIN = -1
RNGFND2_TYPE = 0
