Hello Gents there is no Serial 7 port on latest Mission Planner cannot set my new Matek 743 up.
Hello @MartyMcFly that is not an MP issue. That is a ArduCopter issue. What version are you using? Is it from custom.ardupilot.org ?
Hi Amil Carl,im usung the latest 4.6 dev nightly and hope all is good with you
Did you set BRD_ALT_CONFIG to “1” and rebooted?
No I did not because im a dumpling lol,thank you
Hi Amil-carl very strange in the set up tabs for serial ports there is a serial port 7,in the configs tab there is no serial 7 and now the only way I can get F port to work is on uart TX 4 which is serial 6,need to check telemetry some thing strange going on
Im getting dafter by the second all this methodical set up effecting my quarter brain cell I had the Serial 7 set as a favorite for when I was trying to get Yaapy to work and it was hiding from me keep smiling
Collect those edited .param
files. You will be able to reuse them between builds later.
