Great project, and Im proud to be working with it!
Im working on an automated yard sentry bot, and trying to use ArduRover as the base for it’s design. I currently don’t own any RC Transmitters or Receivers, nor do I really want one adding to power consumption and design complexity. So far I have had no luck getting things configured. I cut my teeth with a ArduSub based BlueROV. While I never completed that project I did get the electronics chassis completed with Pixhawk 2.4.8, Pi, Pi camera, Pixhawk power module and esc. (And moisture sensors and gripper control also). Never at any time did I need a RC receiver/transmitter (which wouldn’t work under the water anyway).
So all that being said Ive read tons of posts, opinions and understand why this is normally a requirement for aerial vehicle. I was reading in another forum about a switch that can be used, but then in that thread it was saying that it was in an much older build.
Bottom line, is this possible? Is there a branch that supports this? At the moment I have an standard rock crawler chassis, 2x18650 cells in series (may need more power, but a good test setup), Pi4 powered off battery with dc-dc buck converter, Pi camera, Pixhawk 2.4.8 flashed with latest ardurover, GPS/Digital compass plugged into pixhawk, ultrasonic sensor (not implemented yet), brushed motor, ESC, and steering servo, plugged into Pixhawk PWM ports, and will also be using these ports for camera Pan/Tilt. Im also going to be adding solar, or wireless charging dock for it to go back automatically when battery low.
This is essentially an blueROV setup except all command and ground control will be over wifi.
If there is a thread/tutorial or faq covering how to bypass this need, I apologize, but I haven’t found anything relevant or that works. Usually just people saying NO, don’t do it.
I also understand that there are a lot of variables getting the servos and speed controllers right, but it shouldn’t be too hard, movement being 1 steering servo and 1 ESC.
Thanks for anyone who can “steer” me in the right direction
If it’s not possible, Im thinking I can get a Radiolink T8S 8 (TX)/ R8EF (RX) combo. Looks like it should be directly supported and cheap.
Bryan
