I am having no luck getting PWM outputs to my ESC and servo. The logs show PWM output, servo tab shows PWM output, but when I connect my oscilloscope, I get no PWM. When it is all connected, the ESC and servo act as if there is no PWM being received as well. Any idea what I’m doing wrong?
Hey there,
Did you ever get this solved? having the same problem. Trying to scope the PWM so we can get a feel for the signal. That being said we have just the flight controller with minimal inputs (Prettym much GPS)…
I did get it figured out. I don’t remember exactly the issue, but I think it had to do with the throttle not being set to 50% on arm, rather I had it set to minimum on arming. There were also a few parameters that needed to be set up properly. Check the throttle parameters for your configuration and see if that fixes it. The other option is the safety parameters.
