Parameters are not displaying on mission plannar, while after connecting pixhawk with all connections.
Help me to solve this problem
Help us help you. Post a lot more details.
We are not good at guessing.
Main led is not blinking in my pixhawk, it is connecting to mission planner but the parameters are not showing in mission planner.
Previously it was glowing but now it is not , suggest me how to solve this.
My pixhawk model 2.4.8
As mentioned, we need way more information.
My pixhawk is powered through USB
I connected pixhawk with USB
I used windows 10 operating system
The settings on my MP at top right
My Quadcopter view
The data at left side of MP
I don’t have Windows10 so not 100% sure, but the pixhawk should be listed differently.
What other options do you have in the drop down list?
Also the baud rate is almost certainly wrong. - usually more like 57600 or 115200
I too have mac OS, but MP doesn’t support in it ,I can install APM planner in mac OS if it is necessary .
Can suggest me how to check,that pixhawk is it in proper state or not
After giving baud rate
No change
Is “COM7-1GENERIC” the only choice in the drop down list?
Which operating system do you have??
I use Linux.
Anyway, MP is connected to something as indicated by the icon on the far top right.
Click disconnect - wait until it shows disconnected icon -then click connect. The connection window should pop up. If it cannot talk to Pixhawk it will tell you after 30 seconds.
Then repeat above process but after icon shows disconnect state change baud rate and press connect again.
I had all my flight-controllers work on USB with either 57600 baud rate or 115200
→ Just noticed, you are connected just not talking for some reason. You can see this in the very top of your screen where it says " ArduCopter 4.2.2"
Found the problem: In the screenshot that you’ve sent earlier it states in red “Config Error: Fix problem then reboot”
Somehow your configuration is messed up.
…that’s why nothing else works
So ,how I can check step by step to clear the mess occurred here
Can suggest
Disconnect USB cable. Wait a few seconds then connect it again.
See what Mission Planner does at the top right regarding the connection icon and also to the left if “Arducopter 4.2.2” is showing again.
You may have to click on the config tab / icon and see if initial settings are still there.
Is this a new setup of drone?
If so, then certainly won’t work as you need to setup and calibrate everything first before you get any correct function on the main screen of MP.
Ahh, there you go. Never seen that screen.
But I believe this may be linked to the bootloader of your FC
Here is the answer - at least appears so:
