Any idea how I can turn the descriptions back on?
See post below - thank you Andras Schaffer
TIP - you might have to click on Parameter Tree, then back to Parameter List to refresh the list.
try regenerate parameter definitions. Press CTRL-F and select Param gen
Hi, I have the same problem. Yesterday I updated Mission planner to 1.3.70 build 1.3.7277.34800 V4.0.2.
Now my in standard params I don’t see the menu on the right hand, and I can’t load saved params and settings. I tried with F7 to param gen, but also this doesn’t work. Any suggestions? Thanks Herman
Standard and Advanced params has buttons on the top. and you cannot save/load param sets.
Go to Full Params List or Tree, the right hand menu avail only there.
F7 key does nothing in Mission Planner
Sorry, not in that name. It’s called in this version: extended params. And in this list (looks like full Parma list) is no menu on the right side.
well this is how it should look like when connected to a copter. There is no Extended Param tab, and AFAIK newer was.
I thought I downloaded the latest version, but you have a newer one. How is that possible? I will delete my version for full and download the version you use. I hope so. Do you have a special way to download that?
Mine is beta and customized, but CONFIG panel is the same as your 1.3.70’s
Mine isn’t the same as yours. I will make a picture and send it to you.
Mine config menu isn’t the same as yours. I will make a picture and send it to you.
Sigh…
As I told in my first reply to you. Go to Planner menu and change layout from Basic to Advanced, then change tab to Flight Data and back to Config.
Thank you for your help Andras
Thanks and again thanks. It was a smal issue (in planner from basic to advanced) and I got the list and tree. Many greatings, Herman from The Netherlands.
Hi Eosbandi,
I’ve lost all the parameter description after clicking on ‘Param gen’. Don’ know how to get them back.
My vehicle is 3DR SOLO with FW 3.5.4 connected by UDP.
bests
Antoine
got it!
I connect by usb my other quad and did ctrl+F then ‘param gen’. Before, I didn’t see the green button pushed meanning it was downloading by wifi? This time, I wait a while, when it finished it closes the window automatically, then I restart MP and it woks now.
Reconnect Solo by UDP to MP and it works too.
Thank you Eosbandi
@Eosbandi
hello,andras.
I did as you said above. The basic and advanced parameters still missing. Can you help me out of this?
