I just upgraded to mission planner 1.3.70 and now when I open the temp screen with extra information (ctrl-f) I cannot see the status of my cube sensors. On the right of this screen there used to be a table showing the information of whether sensor are present, enabled and healthy, which is not shown anymore althoough it seems that there is space reserved for this.
Is this feature moved to a new place?
If not, is anyone else having the same problem or is it just my computer?
It seems that the function was removed at 1.3.69.
Current beta has already rearranged the temp window to eliminate the space left.
For sensor checking there is the HW ID tab in the Initial Setup menu, which shows your detected sensors, and if a given sensor does not work, you should get a BAD … HEALTH message in the messages tab.
