No module named pymavlink ERROR
when trying to run:
sim_vehicle.py -w
I am getting an error saying:
Traceback (most recent call last):
File “/home/odroid/ardupilot/Tools/autotest/sim_vehicle.py”, line 25, in
from pymavlink import mavextra
ImportError: No module named pymavlink
I was wondering if anyone has come across this error or knows what I am needing to do to stop this from happening. Thanks.
you can install pymavlink with pip
pip install -U pymavlink
a search in the ardupilot source code found this:
modules/mavlink/README.md
13:* Source: Mavlink Generator
14:* Discussion: Gitter Channel
I just happened to need the latest version of ardupilot, so i cloned the repo again. After the initial git clone command you need to cd to the ardupilot directory and run:
git submodule update --init --recursive
That will sync and download various submodules need by ardupilot, and I noticed pymavlink was one of them.
I did the pip install. Now I am left with this error.
RiTW: Starting APMrover2 : /home/odroid/ardupilot/build/sitl/bin/ardurover -S -I0 --model rover --speedup 1 --defaults /home/odroid/ardupilot/Tools/autotest/default_params/rover.parm
[Run MavProxy] An exception has occurred with command: ‘mavproxy.py --master tcp:127.0.0.1:5760 --sitl 127.0.0.1:5501 --out 127.0.0.1:14550 --out 127.0.0.1:14551 --map --console’
[Errno 2] No such file or directory
SIM_VEHICLE: Killing tasks
you need to update the submodules under ardupilot:
after git cloning, cd to ardupilot directory and run
that will download many more modules needed by ardupilot, including the python scripts you are missing.
you should also run git submodule update --recursive after updating ardupilot, for example when checking out a branch or running git origin pull.
when I do either of the commands you say it does not show anything on my screen. I hit enter and then it just goes straight to the next line waiting for another command. Thanks
also after I run sim_vehicle.py -w -v ArduCopter. I get that output still but I forgot to say that I get another screen called ArduCopter and it says stuff and the last line is waiting for connection…
what directory are you running the command from? I need to look into running SITL. Did you have to build ardupilot first? Without submodules the build should have failed.
it is working now for some reason.
It takes a couple of minutes to start on my laptop. If necessary you can install mavproxy with pip.
I’m having this same error. When I try and run git submodule update --init --recursive I get this:
From https://github.com/DroneCAN/libuavcan
 * branch              3ef4b88d96466bbcf886f74d0ae169a4c8c1bdb0 -> FETCH_HEAD
Fetching submodule dsdl
fatal: remote error: upload-pack: not our ref 192295c4f9b67f4a20b0eabf74757b6597415f2b
fatal: the remote end hung up unexpectedly
Fetched in submodule path 'modules/uavcan', but it did not contain 3ef4b88d96466bbcf886f74d0ae169a4c8c1bdb0. Direct fetching of that commit failed.
Hi Ben,
Out of interest try to run the following file,
./Tools/gittools/submodule-sync.sh
OK, I have run that. Now I don’t get an error mentioning uavcan, just module not found (future or pymavlink, depending on whether I run python3 sim_vehicle from the autotest directory, or just sim_vehicle.py from any other directory).
I think this is a pythonpath issue:
  • When I run “which python3” I get /usr/bin/python3
  • When I run “which pip3” I get /usr/local/bin/pip3
How can I move/point pip/pip3 to the same place as python/python3? This is a fresh installation and I’m confused why pip is in /usr/local
Definitely do what python says, I believe it is pip install future
I’m not a python install expert but here is my info. below.
(base) veritas@DESKTOP-V9LAGA3:~/ardupilot$ which python3
/usr/bin/python3
(base) veritas@DESKTOP-V9LAGA3:~/ardupilot$ which pip3
/home/veritas/.local/bin/pip3
Would you push to text file all of your errors and the command used?
What is your os? What computer you are using on? I got it working on most os except for some SBC with vendor customized os.
