when i connect the pixhawk to mission planner its (no gps) or (gps not fix with external gps)
and not give me position
Then perhaps you do not have a GPS (NO GPS) connected to the flight controllers (or connected wrongly) , or you are indoors, and your GPS receiver does not see the satellites
thank you for your quick response but im outdoor and GPS IS OK
The right serial port selected/configured?
Well, it is obviously not ok.
NO GPS means that the FC does not recognize any valid communication on the port set up for GPS.
NO FIX means that the FC can communicate with the GPS but it does not receive enough signal to establish a location.
What FC/GPS do you try to use ?
hi
thank you for your attention
FC is the oldest one (PIXHAWK 2)
GPS is SE100
sometimes getting signal and location but still message (no GPS) if only pixhawk internal GPS.
And message (GPS not fix) if im using external GPS
Thanks a lot
