Running 4.3.4
Pixhawk 32 V5
Using the GPS that comes with the kit, there are 2 problems:
Suddenly i get a message on the MP: “No GPS”, there is no light at all on the GPS itself, and also in the compass menu, there is no external row in the table (it used to be…)
Have you configured the correct serial port to use it as a GPS, are you in a building that would inhibit getting a GPS fix? possibly post a param files so we can look and see. plus providing as much information such as what port you have it hooked to will also help troubleshoot issues. the more information you can provide the better folks will be able to help you.
Hi
There is a red light on the saftey button, so it`s not a power issue, regarding the wiring, there is only 1 10 pins cable that connects to the GPS port…
