Hello guys,
i have a problem with the GPS.
so here is the detail :
- i want to test my plane before going to do some mapping job. (test the auto flight mode)
- i’m using The Cube with Here as a GPS
- i’m running arduplane 3.8
- this is not the first plane. this is the 4th plane, i have no problem with plane number 1, 2, and 3.
Problem detail :
- Preflight was done. no problem occurs.
- i did autotake off
- after the plane reach the first waypoint, the GPS status suddenly go to No GPS, with no sats and High HDOP. But the plane still on the track.
- switch to RTL, and the plane come home with correct home points.
- switch back to auto, the plane flying to the track again, and get some Sats.
- after few minutes, the GPS Sats change again to no gps until the rest of mission (Plane come back safely).
Here is the .bin file : https://drive.google.com/open?id=1aq8v-sgdYxtDQr-w6xNsICX3ojraKi02
Here is the .tlog : https://drive.google.com/open?id=1yWldpL2Nb7UoS2c7yKergaLwdkfNNIqn
Problem occurs on time 16:46
and if you want to see the tlog it start from 67.90%
i’m curious, what wrong with my rig ?
why the plane still on the track, even can go home safely, while there is no gps ?
i hope someone can explain this.
do i have a broken GPS ?
Thank you.
