i just changed my old APM 2.6 withe a new Pixhawk 4 FMU V5.
ArduCopter 3.6 was loaded without trouble. My problem:
My APM Planner 2 dos not show the “Extended Tuning tab”.
I already tested my old APM - woks great
and updated the Planner from 2.0.24 to 2.0.26-RC2 - no changes
@zimmi200 Some questions regarding your problem.
Did you enable the Advanced Mode in the File menu? If not do so and check again. If it does not work please answer this questions:
Which platform win, linux, osx are you using?
Updated to 2.0.26-RC2 means you downloaded a new version or did you build the planner by yourself?
How is this new fancy hardware connected - USB?
Are you only missing the advanced tuning tab - meaning does anything work as expected?
I tried but failed to reproduce your issue - with the Simulator and with my old pixhawk v2. I hope I will have some time this weekend to do some further testing.
I installed Mission Planner 1.3.58 and APM Planner 2.0.24 on a Win7 Notebook.
Same issue on the APM Planner but the Mission Planner shows the Extended Tuning tab.
I tried everything - when using Arducopter I am not able to reproduce your issue. All Copters do have the “extended Tuning” settings.
It would be very cool if you could upload an APM-Planner log (can be found in /home/user/apmplanner2) for further analyzing and please open the “mavlink inspector” (Tool Widgets->Mavlink Inspector) and tell me the value for heartbeat -> type.
