In MissionPlanner no Com Ports are shown in upper right corner.
I downloaded the PX4_win_Drivers.Zip file and extracted it in Windows Download, I have two files in Zip file,
PX4flow.inf
PX4fmu.nf
I have Windows 7 64 and have no issue with com ports. When you installed Mission Planner it should have loaded those drivers. It may have showed a window looking for windows drivers on the internet which you should click on the stop looking for driver and install from local.
In device manager it should show up under com ports as PX4FMU (COMxx)
My problem is I can’t get the two .inf files to install in Windows 7 Pro 64bit.
In windows 7 in Device Manager doing a right click and in “Install” does work, there is no “install” option.
How do i install the two .inf files ?
Try right clicking on the inf files and you should see an install option. I’m not sure this will solve your problem, but the method is a Win7/8 standard.
I even went to pixhawk.org/firmware/downloads and downloaded the Drivers from there and did a /extract/right click/install and got the the same error message ;
" The Inf file you selected does not support this method of installation"
What other way would I install the .inf files ?
I clicked on the wrong thing, this post is not SOLVED, How do I remove that from this post ?
