Hey, I’m having a bit of an odd issue with APM Plane in my Bixler. I have a 3DR Pixhawk, 3DR GPS/mag, 3DR power sensor, 3DR radio, and an analog pitot tube in this plane. Along with that, I have my radio(turnigy 9XR and FrSKY DJT) and in the plane is a D4R-ii bound and in PPM mode.
I am able to radio calibration, and see my stick values update on screen. I can even successfully switch between my 6 flight modes. But I cannot do transmitter arming, and even when de-activating the hardware safety and arming through GCS, I still cannot move any servos or the speed controller. Plugging them directly into the D4R-ii confirms the servos and ESC work, and I can confirm the servos are plugged in properly to the Pixhawk, as the ESC arms when I de-activate the hardware safety, and the servos are holding position at 0 degrees.
Is there anything I might be missing that is stopping the pixhawk from passing my controls to the outputs? Even in manual mode I am getting no control at all.
If it helps, I attached my parameters on pastebin: pastebin.com/AhFSTGLG
