I’ve been setting up throttle fail safe according to the directions here: https://ardupilot.org/plane/docs/apms-failsafe-function.html. Failsafe seems to work fine according to the tests, however, I do not see a drop in the low ppm value when I turn off the transmitter. I should be seeing a drop below 982, but I am not apparently. Why would this be happening yet failsafe functions as expected?
Also, is it normal to have a slow beeping from the motor every few seconds while the plane is disarmed? On arming it stops, and all appears normal.
Thank you much.
