dear friends,
with my test copter im testing a little bit the new firmware 4.0.
I was really happy when I found out that suddenly with this new firmware I get an NMEA out on a serial port
Serial2_Protocol: 20
when i look at the strings in putty I find out that they are only running for excactly 58sec. Then it stopps and Serial2 seems to be totally dead.
shame on me… i can build, adjust, fly copters, rovers, boats but when it comes to all this Git stuff I´m at the Moment unfortunatly out.
But, because I learn and enjoy so much the last years about this “projekt” thats gonna be my next level!
I wonder if this was the same issue I was having with nmea our on my plane 4.0 setup. Also my tracker that it was hooked to was only showing 6 satellites even when I had at least 12 locked.
@sparkyincali, this would only affect the NMEA output which is mentioned on this wiki page. It’s not related to NMEA input from a GPS so this problem wouldn’t cause a NMEA GPS to report fewer satellites than expected.
Yes that is what I was referring to is using option 20 on a serial port. My flight controller is being fed by a ubx gps and I was trying to use the nmea output to feed into a myflydream telefly tiny so it could encode the tracking data into the video stream.
