For the OpenPilot Revolution I followed night-ghosts instructions here Flash firmware · night-ghost/ardupilot Wiki · GitHub to get a bootloader. Then I just fetched the latest ardupilot mainline code (commit f75dea3), did a submodule update
Building and uploading worked fine for me. I know it has been said before, but this is very cool, very nice work! Can’t wait to see how this FC compares to a Pixracer.
Anyway, I also have a CC3D Revolution Mini here, which I would also like to try, but I don’t know how to get it into BL mode. Any hints?
OK after another hour of searching I found it: http://drone.hjns.net/openpilot-cc3d-mini-revo/
Same method as above worked. Weird is that it will only boot every other time, but I’ll have to test this more. For now I am very happy.
@moobsen, correct me if i’m wrong, but what you‘ve built with the above mentioned waf command is chibios for revo-mini, which in fact is nice too, but not exactly f4light.
Yes Basti, what @moobsen has done with waf command is build for revo-mini with chibios HAL.
To build for revo-mini with F4light HAL:
cd ArduCopter
make f4light-clean
make f4light
I think that it would be better to be able to also build F4light with waf.
It would be more convenient especially for uploading and would easily allow you to switch from F4light to Chibios (and viceversa) for testing.
andrea,
i‘m quite far from considering myself in a position to judge different build environments, but yes, for someone like me who builds code only if it can‘t be avoided, waf seems like a pretty convenient solution.
that being said, the required definitions are way beyond my scope as per now, having successfully set up the build environment for the first time only a couple of weeks back. but eventually we‘ll get there
this was not an issue of compile environment but result of changes in Dataflash_backend API while Dataflash_File_SD was left unchanged. So may be WAF is much much better than old Make, but it would not be able to prevent that build error.
@night_ghost what I said about waf was only relative to the easy of building and uploading, I never thought that could solve those kind of problems, and I think also the comment of Basti was in that direction.
Anyway my problem with uploading is when I try to go back and forth between f4light and chibios (for omnibus f4 pro as example):
with your bootloader and f4light firmware I am able to flash new release with reboot in DFU and flash with dfu-util
with the same bootloader I am able to build and flash chibios based firmware
./waf configure --board omnibusf4pro
./waf copter
./waf copter --upload
when I try to flash again f4light firmware at this point I have no more the possibility to boot in DFU and I think I have to flash a .apj file in this way, but it doesn’t works.
I hope there is some command line tool to flash bin or apj using the bootloader.
I retried to build f4light from ardupilot master commit 1fd52c4 but obtain the same error in DataFlash:
%% libraries/DataFlash/DataFlash.o
/home/andrea/src/ardupilot/libraries/DataFlash/DataFlash.cpp: In member function 'void DataFlash_Class::Init(const LogStructure*, uint8_t)':
/home/andrea/src/ardupilot/libraries/DataFlash/DataFlash.cpp:113:79: error: invalid new-expression of abstract class type 'DataFlash_Revo'
backends[_next_backend] = new DataFlash_Revo(*this, message_writer); // restore dataflash logs
In file included from /home/andrea/src/ardupilot/libraries/DataFlash/DataFlash.cpp:10:0:
/home/andrea/src/ardupilot/libraries/DataFlash/DataFlash_Revo.h:46:7: note: because the following virtual functions are pure within 'DataFlash_Revo':
class DataFlash_Revo : public DataFlash_Backend
In file included from /home/andrea/src/ardupilot/libraries/DataFlash/DFMessageWriter.h:3:0,
from /home/andrea/src/ardupilot/libraries/DataFlash/DataFlash.h:33,
from /home/andrea/src/ardupilot/libraries/DataFlash/DataFlash.cpp:1:
/home/andrea/src/ardupilot/libraries/DataFlash/DataFlash_Backend.h:42:18: note: virtual void DataFlash_Backend::get_log_info(uint16_t, uint32_t&, uint32_t&)
virtual void get_log_info(uint16_t log_num, uint32_t &size, uint32_t &time_utc) = 0;
../mk/build_rules.mk:27: recipe for target '/tmp/ArduCopter.build/libraries/DataFlash/DataFlash.o' failed
make: *** [/tmp/ArduCopter.build/libraries/DataFlash/DataFlash.o] Error 1
sorry but I don’t have so much time to single-handedly fight with the whole Ardupilot team, After those “correction” I stopped to try to fix such cases in upstream, and just do rebase and correct in my fork. I think if this HAL in master, the responsibility “not to spoil” should be on those who do changes. All my PRs are just “cherry-pick’s” from fork.
I think you should open an issue in upstream repo.
Between make and waf, dfu-util and --upload, Chibios and F4Light, and all the various F4-based FC’s, this is not a simple ecosystem, eh? It took me some stumbling this weekend to figure out how to achieve consecutive flashing of Chibios versions, two-stepped: dfu-util to load a bootloader from Bootloader subdirectory, then MissionPlanner custom firmware approach. I think NG’s approach is currently better.
In this way you are building for Omnibus F4 Pro with ChibiOS HAL, to build with F4Light Hal:
cd ArduCopter
make f4light-clean
make f4light BOARD=f4light_AirbotV2
at this point you have f4light_Revolution.apj in the same folder.
To flash using the bootloader you already have:
…/Tools/ardupilotwaf/px_uploader.py f4light_Revolution.apj
Now we have two options also for this cheap F4 boards.
You can do all this by cloning both from the ardupilot master branch and from the night_ghost fork, in this fork there is some additional works by night_ghost.
