Hello everyone!
I am trying my best to learn and understand and absorb the encyclopedia of information about Arducopter, APM, Mission Planner, etc. But it’s kinda hard for this old man, lol…
I have a Quanum Nova RTF aka Cheerson CX-20 with the APM open software. I have had 10 very successful flights and then the 11th flight ended up with an out of control quad and a crash.
The difference was that I had tried my luck using APM and calibrating the compass, the accelerometer, and the Tx. I followed the tutorials and I thought I had performed the cal’s correctly. The reason I even bothered to do the cal’s was because in “Loiter Mode” the copter would not actually loiter. It would wobble and drift around a lot. Versus “Stable Mode”, where it could be held quite steady if there was no wind.
Prior, I had used successfully the Loiter mode, and RTL mode. Both worked just fine, except for the wobble/drift in Loiter. The RTL seemed to work quite well.
Yesterday after performing the calibrations I flew the copter in my backyard, my normal flying site so far. I took off in Stable mode and it flew nicely as before. I then switched on Loiter mode and it very swiftly started to fly backwards and disappeared from my view when it went over the roof of my house. I switched into RTL and I do not know of it actually attempted to RTL but it did not return. I heard loud buzzing noise and spotted the copter in one of my trees merrily chopping up the leaves. I was in a bit of a panic but then remembered to switch back to Zero and the buzzing stopped as I ran to the front of my house. By then the copter was on the roof and I was able to recover it.
Amazingly it only suffered a broken landing skid. Getting back up on the horse, so to speak, I then flew it again in Stable mode which was successful. But I am now afraid to try Loiter Mode until I sort the issue out.
I read the tutorial on downloading logs in Mission Planner and I was able to save three logs, which was everything in the onboard memory. They are huge, 2.7MB each. Could that be right?
Anyway, I tried looking through them and tried to figure out how to use the graphs, analyzers, etc but it’s currently WAY over my pay grade!
I suppose a simple question would be, is it possible I goofed up the compass calibration procedure? Should I perform it again? Does it matter that I was inside my home when I did it? Does it actually require being outside Like I saw in one video with the gent spinning around with his quad?
I mostly fly it in Stable Mode, but I would like to be able to use a nice and steady Loiter Mode from time to time.
Well, thank you if you have read all the way through this enormous post.
