Bought 2 new esc’s. For 2 motors do i need to mix 3 channels in the transmitter first like in the youtube videos? Or do i just need to wire the Pixhawk and to the config on the GSC software?
Is the right motor and left rotates in the opposite directions?
The esc is reverse capable but these are brushed motors and I don’t need this right?
I really got everything but i just don’t want to burn stuff. Thank you for the support!
(I’m aware of cutting the power line of BEC’s to pixhawk when connecting)
Most likely on that boat the port prop turns CCW and the starboard prop turns CW looking at the transom. But you can just look at the props and figure that out. You would need the motors to reverse if you are using typical skid steering but I suppose in stock form it will not reverse or zero turn and maybe you don’t need it to.
Well, it’s obvious which way a prop needs to turn to generate forward thrust you don’t need a video for that but whatever works for you. Yes, reverse the 2 wires to the motor to reverse it’s direction.
Make sure you have one left hand prop and one right hand prop on the boat. Putting one prop on backwards to have counter rotating props is not the way to . I don’t know what your drive train set up is.
