Hi Everyone, thanks for the great work and making it possible for guys like me to build flying machines! Long story short I have created a large vtol tilt rotor quad plane with no gps or sirspeed sensor. I can not get a good hover in arduplane but it hovers fantastically with copter. I need a manual mode for forward flight. I can make do with no transitional mixing. Any chance someone wants to add manual mode to copter for me? I’m not rich but I would be willing to make a donation to help out. I just need 4 motors with no stabilization just in and out. I use x8r with subs on all of my crafts (there’s a lot of them) in case that matters. Thanks in advance!
Acro mode with trainer disabled won’t work for you?
Maybe it will… I will look into it a little and see. Many thanks for the reply!
Hi Dave, so I finally got around to building everything and I’m commissioning the systems. When I switch to acro mode with training disabled it continues to provide some sort of stabilization with stick inputs… the motors change speed… a.m. I missing something simple? Thanks
Colin-I’ll have to admit I have not flown much Acro non-trainer mode with Arducopter. Maybe some of the tuning parameters shown in the Wiki will help?
http://ardupilot.org/copter/docs/acro-mode.html
Hey thanks for the reply Dave, I’m just putting the finishing touches on an early stages prototype maybe I’ll send you video in the next few days and you can tell me what you think. I have not got past cover yet but that supposed to happen this week.
Sounds like a cool project!
Hi Guys, so we have our prototype hovering perfectly and all bugs are worked out except for the final piece of the puzzle. When we switch from hover to forward flight all rotors tilt and we no longer need stabilization or any stick inputs other than throttle. We have a separate flight controller bound to same rx handling the control surfaces so we can’t lock out stick inputs through the taranus because we still need the sticks to give inputs to the other flight controller.
So I think my only option is A… another flight mode with no stabilize at all and no stick inputs other than throttle. So all motors react only to RC throttle nothing else.
Or B… a way to disable all stabilization and 3 inputs ail, ele, rud somehow at the flick of a switch. Like RC_overide for each input and stable_overide. And then switch could be assigned some how to enable those.
I I am willing to donate cash or drone parts if someone can help with this. Thanks
can you not duplicate the the sticks to different channels in opentx mixer? ie use 1-4 for hover and 5-8 for forward flight, you could then fix the first lot of inputs except torottle on a opentx switch.
If you want a better way of doing it i think it would be better to improve the quadeplane code to allow better hovering, then you would only need one flight controller. Is it just that you have no GPS and that is not a good idea with the plane code? I see no other reason why copter should be better than plane at hovering?
Hi Pete, Happy Sunday! I spent days and days trying to get the quad plane hover to work out but it just would not work out. For now the copter hovers better than anything else on the market as far as I’m concerned. And seems best at recovering.
I’m trying to wrap my head around duplicating the sticks like you suggest. So while hovering in stabilize inputs are as normal. Then I flick a switch which tilts rotors, changes flight mode to acro so no stabilization. That same switch must also lock out Ele, ail, rud so only the throttle will work. But then it will lock out those three controls for the other flight controller. I’m trying to understand how I can still have those sticks work for the other flight controller for flight surfaces…
Just use the open tx mixer to output ele ail and rudder on two channels each, then set one lot of them to be disabled for the quad controller and set the plane controller to uses other channel numbers for ele ail and rudder, you can do this in ardupilot by setting the RCMAP_PITCH, RCMAP_ROLL and RCMAP_YAW parameters.
So you could duplicate the roll pitch and yaw on channels 14,15 and 16 then set those as the inputs using the RCMAP paramiters
acro still has stabilization is just based on rates not angles, you will find the quad fights the plane if you try and change directions, the Quadplane code is defiantly the way to do this properly. What sort of airframe is it? There are loads of different things running the code successfully.
Hi Pete, ok gotcha on the rc map stuff. I can make that work. So acro with trainer turned off will still attempt to stabilize? Hmm… you are right about the quadplane thing but I went down that road for a while and I am closer now. How big of a deal is it to make a new flight mode? or even a parameter for acro called “RC pass through” that would allow the motors to only be controlled by the throttle stick with zero stabilization? Is it a big job for someone who knows what they’re doing to make that change in the code? I really think that’s my best path forward right now…
it would be straight forward for someone to make a custom fork with just straight pass through, you could probably do it yourself by copying how the esc calibration code does straight pass through and just over righting that to another mode
are you interested in doing that for me? Or anyone else following along? A flight mode with pass through on all outputs and an option to disable stick inputs. I would be willing to Donate to the cause or send some free stuff… or a gift certificate to someone’s favourite drone store… something like that. I’ll bet that flight mode would open the door to other innovative ideas as well
I could possibly make it work in a bodge way, probably better to find someone who knows what there doing, I can’t see it being merged as a copter flight mode, its too specific. There would be much more interest in making the Quadplane code work better for your setup.
I’m ok with bodge… just let me know what I can do for you in exchange.
So what do you think? Are you interested? Or do you know anyone who may be interested?
I have had a quick look, i think you could do this quite easy by either adding a new mode or replacing a existing mode, the key line to add is set_throttle_out_unstabilized(float throttle_in, bool reset_attitude_control, float filter_cutoff) line 150 libraries/AC_AttitudeControl/AC_AttitudeControl.cpp
for example you can replace lines 40 to 50 in mode_acro.cpp with the above line, and it should work
Instructions to compile and add new modes are on the developer wiki, once you have it compiled you can upload using mission planner upload custom firmware button, then trying out with no props on.
Hi Pete, Thanks for your reply and I’ll bet I could figure it out but I’m going to leave it to someone who has done this before. Can you point me in the direction of someone who may want to do it? Like I said I’d be willing to compensate. Thanks
