Since I loaded last update of Mission Planner, every time I open a Flight Plan Waypoint file and pull up the waypoints table, is compressed and cannot be read until I add a new Waypoint. See the lower left corner of the attached screen shot.
Same issue for me as well.
I have the same problem. The workaround seems to be to load the WP file again, and then you get a readable display.
thanks for the SS I had not seen this problem before, it should be autosizing, but seems to be failing
