Give it a second test. It works a lot better when you scroll all the way down on the “component editor” window, like explained in bold on the top of the window and on the documentation
Don’t have a scroll bar. Put all elements on screen. Have some interactive elements and warnings. Maybe a library of hardware from which to choose. Less typing. More clicking.
At some point, the user shouldn’t even have to care that they are modifying hundreds of parameters. They should just be able to select behaviors.
I had 5 windows open. One with the configurator (that I had to keep closing and opening, apparently by design). One for MP. One for the documentation. And two text editors to ensure I was getting what I wanted in the params. That’s 4 too many.
The hardware information in the “component editor” window is already user to automate parameters in multiple locations, Making some parameters disappear, appear or change their value. And it is all editable in a .json file. No python code changes necessary.
It automatically edits the files as you go, there is no need to generate a perfect template!
But yes, these “hardware dependent automated parameter changes” are far from complete and must be improved and extended with input from you and other users. Thanks for your input!
In your double and tripple checking in mission planner did you find any instance where a parameter was unexpectedly changed by AMC?
Some of this can be automated by parsing things like hwdef files, such that a bespoke hardware library doesn’t have to be maintained.
Already mentioned the niggling issues regarding add/delete along the way. I’ll add that any *ENABLE parameter can have the side effect of forcing “N/A” params to show up until that feature is actually enabled.
I didn’t see any bugs in that regard, though I did a lot of back-and-forth because of my initial mistake regarding template setup.
I did somewhat frequently notice this: I’d make changes to the displayed params without actually advancing to the next step, in expectation of doing that soon. But if I had to close and reopen (the reason for which was already mentioned), those changes weren’t saved. It only saves on step advancement (or writing params to hardware), but not on live changes. So there was duplicate work (which was part of my rationale for having text editors open).
Is there a way to “remember” the COM port and poll for that port’s existence when disconnected?
Or like MP, make it a menu selectable item that is always available to the user?
It is usually better to have an almost stateless software. It prevents bugs and is considered good design. So I do not store for now. On linux the issue does not exist. My guess is that @tridge and other pymavlink developers do not use windows often enough to notice this autoconnect bug.
I had that in the first couple of versions of the software, but abandoned it to make the software interface less cluttered and simpler to use. This was a good decision, once that pymavlink bug is fixed
I strive to make the interface easier to use, with no hidden menus. So far looks like I have not done a good job at intuitiveness, but I feel I did a good job at minimalism
Of course best to fix the root cause, but a “force reconnect” option, even if just a temporary hot key (and not a permanently hidden “feature” like MP has so many of…) might work for now.
There is value in both, of course! I used to write a lot of mission planning and execution tools when I managed an austere flying operation. I’d start by writing something for myself - sometimes as simple as an Excel spreadsheet with a bunch of formulas and no formatting. Either someone else would notice my use of it, or I would find some value in sharing it. I’d seek out the least computer-savvy team member and hand it to him or her with only a description of what it was supposed to do. If he struggled, I knew I either had more work to do or had to abandon the tool entirely. On the other hand, if he immediately caught on and enjoyed the newfound efficiency, I knew I was onto something and would spend more time refining it.
That is by design, to give the users full control over when the files get saved. Saving only happens when the user selects “write” or “skip” buttons. I was hopping that would be an intuitive way of doing it.
Alternatives:
Autosave on every change. Simple to implement but is an overkill. Users have no control
Implementing undo and redo. Much better but complicated to implement and prone to bugs.
