mon drone est sous mission planner 1.3.81
copter V4.4.4
Pixhawk 5X avec alimentation PM02D holybro
BATT_MONITOR= 21
BATT_I2C_BUS=1
BATT_I2C_ADDR= 0 détection auto ou 65 (pour le module numérique 6S)
j ai un problème d affichage du courant il est négatif ?
le voltage est ok
je ne trouve pas la solution avez vous eu le problème ?
Welcome to the community, please try to keep communication in english.
Try to put a non-negative number in the current calibration field.
The current monitor of the PM02 works by sending a voltage proportional to the measured current. Ardupilot needs to know what voltage represents how much current, that is what the calibration is for. So if you put a negative number in the calibration it will interpret the voltage signal from the PM02 as negative current.
I don’t think I can help you anymore, as far as I can tell your setup looks good.
Also I don’t have a PM02D to play around and try to replicate your problem.
Sorry
