Need Suggestions! ESC ~150Amp sensored and brushless
Hey.
Maybe an easy answer? Perhaps, no!
I need an ESC with forward/break function. Specifically; the ESC needs to be able to go from forward to reverse (brake or no brake, no matter) inputs without any manufacturer added user safety-inputs (ie. stick to neutral, hold and then reverse - or - double click method).
It will be used on a fan boat. Low Kv motor. 4C system. So I hope the amp draw to stop the prop and change direction will not be too much to hurt the ESC.
Anyone have any suggestions. Price… would be great to be under $200
Thank you so much if you can help me out!
Neil;
