Motors 1 and 3 are generally lower output that motors 2 and 4, indicating some weight imbalance to the rear, and sometimes 1 and 3 are momentarily reaching minimum output. You might be able to set you MOT_SPIN_MIN a bit lower like 0.13
You can set INS_HNTCH_REF to 0.171
I’d be interested to see a log with these set to check the HNTCH settings, but it seems reasonable how it is, but it’s not essential.
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,0
If you are sure it’s correct you can set INS_LOG_BAT_MASK,0 to reduce logging.
You can set these since there seems no danger of fly-away
ATC_THR_MIX_MAN,0.5
PSC_ACCZ_I,0.342
PSC_ACCZ_P,0.171
After you’ve balanced the weight a bit better and set those other params, you can run another Autotune, or at least do another test flight with a bit of hovering and some gentle maneuvers - don’t worry so much about deflecting pitch and roll to their absolute maximums.
