in similar drone we have, compassless, but with optical flow sensor and lidar tfmini, we can arm in loiter and have good positioning, always in indoors.
we have trying to test the throw mode in a similar small drone, sensorless, with gps, and we have a lot of problems with the position estimate warning.
any solution to test the throw mode without compass? only with a bn220 gps?
I’m trying to build exactly the same, optical flow + lidar controlled drone for indoor position hold. I have a GPS added recently but I still get this position estimate error. I also don’t have a compass. Could you explain what were the settings you used to make it work? Or even post the params?
I also had that problem and solved it by setting RGNFND1_GNDCLEAR to the same distance that the sensor registers when the copter is on the ground. Hope it solves your problem too
We are building an indoor flying drone with a LW20/C
Lidar height sensor and HEREFLOW optical position sensor. The drone already completed the autotune. Hereflow sensor inflight calibrated. Does anyone successfully fly your drone indoors and hover and hold the position at ±3cm?
We think the height holding is acceptable but not the xy position holding. We tried firmware versions, 4.3.3, 4.3.2, and 4.2.3.
Are there any parameters we can try to look into and improve? Is there anything from the flight log we can analyse to narrow down the cause? Is there a better indoor flight mode than Loiter flight mode? Which firmware do you use?
