Need help identifying Unknown ESC
Before I start, I bought a hexacopter off of ebay and it worked great for the longest time. Recently I flew in a bit of moisture and it caused one of my ESC’s to stop working. When I removed the ESC from the copter, it was shrink wrapped and had no visible stickers or marking of the branding. I cut open the shrink wrap to find many serial numbers and part codes that mainly led to general parts, but one in particular could potentially identify what ESC this is but I could not find out through my research. Please help identify what ESC this is so I can replace it. Thanks.
“DDT-45A-A-01”
3 parts under: “IR2101S0430”
Back of previous segment
Top of 2nd Segment
Bottom of 2nd Segment
How the 2 segments connected originally (before scientific deconstruction)
What motor do you use? How about use another ESC? If you are familiar with pixhawk.
I use T-Motor Navigator series 330kv. I have no issue using other ESCs but I’ve seen issues on this platform in the past of different ESC timings causing oscillations and even crashes due to vibration. I would just need to confirm that what I’m buying will not cause any flight errors.
Have you tried AI image prediction search?
