I’ll contact support shortly. Thanx for the quick reply.
Could you share with me how you spotted the motor failure in the logs? I suspected it (or ESC)but couldn’t quantify it through the log. It’s intermittent. About every 4th or 5th flight. Is that normal for motors to have intermittent failures?
It seems to drive the Pixhawk nuts or is that normal once a crash error is detected?
I don’t mind changing the motor but I’ll probably order a couple more.
I went back and looked at some tlogs and noticed something else strange when this happens.
From the time I powered up the Pixhawk I had bad GPS performance and low signal strength on the telemetry. It was only reading 73% when they were only 20 feet apart. GPS fail intermittently. Noticed I needed more throttle to keep it up and then BAM.
When I have good telem signal and no GPS failures there are not issues. This applies to stab mode.
Could a faulty motor be causing these other symptoms?
