good afternoon, I came here to ask for help for my Navio2.
I have a raspberry pi B, and a Navio2 control board.
I already downloaded the image,
https://docs.emlid.com/navio2/common/ardupilot/configuring-raspberry-pi.
I tried to follow the setup instructions but I don’t have much experience in linux I was unsuccessful, I was asking if any colleague has an image already mounted for Raspeberry with Quadcopter that could share with me already configured, thank you
Olá
The image from Emlid is already configured, and if you follow their install it’s quite easy.
What exactly is the Raspberry Pi you’re using ? 2? 3? 4?
cumprimentos
Olá Luís Vale, muito obrigado por me ter respondido.
Eu já descarreguei essa imagem, tentei seguir as intrusões em que se fala-se de muita coisa, este e o Raspberry pi 3 B que eu tenho, mas eu em Linux tenho pouca experiência, como tinha visto nas instruções que a imagem se encontra vem predefinida.
Se algum tivesse essa imagem já programada queira partilha-la comigo ficava muito agradecido.
Let’s keep it in English. And from the docs here: Introduction | Navio2
ok, So you download the image file from Emlid, and you use a software like Etcher balenaEtcher - Flash OS images to SD cards & USB drives to write that file to a microSD card. This is what you were asking?
From now, you can connect the RaspberryPi to a monitor/TV and use a mouse and keyboard to configure the running software.
The Emlid image allows you to switch between different vehicles easily.
Just type
sudo emlidtool ardupilot
and you have a menu system to change the vehicle type, how it starts, etc…
Ok, how I did it I don’t know. I realized I was working with a wrong image on raspberry.
I already uploaded a new image for the raspberry 3 B, now I have a very deferent monitor presentation I can work on the ship2 configuration, thanks for the help.
