I suspect that the 1st Autotune for whatever reason was bad Gal. I looked at a previous log you posted and compared it to this one. Take a look at what happened with ATC_ACCEL_P_MAX and Pitch P. Those were driven awfully low so maybe no surprise it was wobbly.
Hi @dkemxr Dave, thanks for taking a look at this.
Wobbly wasn’t the issue. There was a battery fail safe which kicked in in my QGC (I heared it) but it doesn’t show in the logs and instead of srtl to home position where it took off, it flew 50 meters away ending its own life on the Stadium gate at 5m/s.
I simply unable to figure out this log. no vibes, nothing to indicate any problem? It even saved the gains after the crash!
So in this log the event shown here is where it accelerated and hit the gate? At 12 m/s it looks like. It shows it’s still in Autotune with some overrides from stick input. But you are right, it doesn’t show a battery FS or RTL. It didn’t reach the low volt threshold or the mah remaining.
Exactly, simply nothing. All the errors we see is after the crash. The quad just flew like 50 meters or so and there is nothing in the log to tell us why? No rc input to do that?
Very weird
