Hello, I’m using Pixhawk2.4.8, Ardupilot, QGC to automate my RC car.
When the car is directly connected to my Taranis QX 7(Opentx transmitter) with Frsky Q8R, it stops at the center throttle and goes forward and backward at the upper and lower throttle. However, when the car is connected to Pixhawk, it only goes forward, which means it stops at 0 throttle. And if I put it into hold mode in QGC, it stops.
Parameters in QGC are in the default setting. The ESC is in forward/reverse mode.
I don’t know what should I do to be able to make the car go backward with Pixhawk.
Sorry for my English. I would appreciate your help.
