I’d like a little help as I bench test my copter. I can arm the system when hooked up via telemetry or via usb. After about 5 seconds the unit will automatically disarm. There are no messages indicating in the flight mode view.
What should I look for to trace down a potential problem?
You need to post a dataflash or tlog for us to tell if anything abnormal is happening.
Sine the GCS is stateless and only reports arm status based a message from the GCS, sent every 0.5s, this isn’t the correct location for the error report, so moved to 3.2
I have tried to find the data flash logs but there is nothing there. When I connect via usb and then download logs under the graphs tab, there is nothing there.
