I have connected SITL with Gazebo and I want to run 2 drones in the same Gazebo session. So far I have run 1 drone, in the Gazebo environment, with the following command:
sim_vehicle.py -v ArduCopter -f gazebo-iris --model JSON --map --console
Given that 2 autopilot instances will be now run, should I change anything in the above command before running it once for each drone?
Hi @keep_coding were you able to spawn and control multiple drones in the same session? I am trying to something similiar, I want to control the drones using pymavlink
. I found a few old resources online
https://discuss.ardupilot.org/uploads/default/original/2X/d/d7083377f747deab79798e7a9cef58d433ff5f66.pdf
it is meant for gazebo-classic but with a few minor changes I was able to spawn the drones in Gazebo Harmonic.
But when i tried using the command in the instructions
sim_vehicle.py -v ArduCopter -f gazebo-iris --model JSON --map --console -I<instance no.>
I get a link down error, still trying to figure out the issue.
Hello @samnt178, were you able to do it? I have managed to spawn the drones in gz sim harmonic, but am only able to connect to 1 drone, the other 2 sim_vehicle.py consoles show unloaded module Console
