Just a simple question but I didn’t find the answer searching on the forum.
I’ve a couple of multirotor Hex, Quad, etc., each of them flight with Pixhawk FC. When connected to Mission planner, the assigned model name is 1 for any multirotor. All logs are saved under the same subfolder:
Hello, thanks for the answer. No problem for the integer. I suppose it’s possible to assign a different ID for each model changing this parameter? If it’s the case, each multirotor has his specific folder, no problem if’ its called with a number.
