I’m doing a project where I would like to simulate two planes flying around each other and will need to see both at the same time.
I’ve got two instances of Mission Planner’s built in simulator running on two separate computers. Is it possible to connect both instances to a single Mission Planner such that I can see both on a single screen? Otherwise, is that another way to display two simulated planes at the same time?
Mission Planner now allows for the use of swarm copters, rovers, and planes. However, if I want to create a plugin that changes the home position of the plane to the GPS position of the rover, I need to run both the rover SITL and the plane SITL simultaneously. Unfortunately, when I turn on the plane SITL, the rover SITL turns off.
I attempted to follow the instructions provided on the following link, Setting up SITL on Windows — Dev documentation. However, I encountered an issue where turning on another SITL instance resulted in the existing instance connection block. I guess this is because both instances are sharing the same address (127.0.0.1).
Could anyone please advise me on how to change the address and successfully run two MAVProxy SITL instances at the same time?
I ran two mavproxy SITL instances, and result was same.
I tried to change the address with this command line, but result was same :
