Hi All. Can someone just confirm the GPS redundancy behaviour with multiple GPS and RTK.
For for example 1 the setup would be 2 GPS by the same vendor like a Here + and a Here 2 so one RTK and one not, a base would be used.
would blending option work in this scenario ?
What about with multiple RTK rovers of the same vendor, will blending work then ?
Reason I’m seeing this is I have seen a number of setups with 2/3 GPS with one being RTK and I just wanted to confirm the expected behaviour and recommended setup in my head.
Thanks.
My believe is if you have one RTK unit and one normal then you shoud not use blending
