I am not sure what you are asking. I read the binary data from the com port and fed it right into a binary file. I didn’t manipulate it at all.
Correct, there was no VTX present. I recorded the data using a FTDI FT232R. I used a script in powershell on my windows laptop to capture and save the data.
Just want to write a quick note to keep those watching this thread updated. @andyp1per was kind enough to do a test with his walksnail VTX and the Zealot H743. He confirmed what I was experiencing in that he was also NOT seeing the OSD Displayport through the Walksnail VTX.
So at least we can reproduce it. Now we need to determine if it is the FC or the VTX.
Here is another update to this thread on my OSD DisplayPort issues with the walksnail VTX. @andyp1per put the UART port of his QioTek Zealot H743 on a logic analyzer and found that he low voltage on the serial port was +1 volts where as most of the controllers he has looked at are around 0.4 Volts
I wrote @Qiotek about the issue to see if they had any insight on this. He confirmed that this is a known issue with the Zealot series flight controllers. This is due to a TXS0108 level shifting chip on these flight controllers. He said that UART 5 is not connected to this chip and the OSD will work on that UART. I confirmed that it works on both my Zealot H743 and F427. So it appears that this is a flight controller issue and not a VTX issue.
Big thanks to @andyp1per and @yaapu for helping through this troubleshooting.
I am looking into ways to implement a MSP OSD for OpenHD.
From a development perspective, it would be helpfull to have a tool that streams msp dp data to a udp localhost port (basically a playback of a recording in raw format).
Anybody here who knows such a tool / has done something similar ?
