How can the IMU health checked ?
I mount a mRo x2.1 Rev 2 on a plane with Arduplane 3.8.4 .
- with Arming Check set to 1 I’m unable to arm the motors
- sometimes on Mission Planner HUD with the plane on ground, the “bad Ahrs” message appears on Mission Planner HUD
- In Mission Planner the EKF window shows all elements in OFF state
If I set Arming check to 0 , the plane flies without problem, the Bad Ahrs message do not appears anymore and the EKF window shows all elements in ON state with all bars showing the grren bar at minimum.
Mission Planner Auto Analysis gave:
Test: IMU Mismatch = GOOD - (Mismatch: 0.33, WARN: 0.75, FAIL: 1.50)
